selmir Posted June 20, 2008 Posted June 20, 2008 Hi, I run 8 instances of DVBViewer Pro on my computer without any problem. When I try to run one more instance nothing is happened, without any error report, just nothing. I have a question: Is it possible to run more than 8 instances of DVBViewer on same machine? Maybe this is a limit of OS? I run DVBViewer on Windows XP SP3 and also I try this on Vista. Quote
Griga Posted June 21, 2008 Posted June 21, 2008 Is it possible to run more than 8 instances of DVBViewer on same machine? No. It's a limitation of the data structures that are used for interprocess communication by DVBViewer. We didn't expect someone to be that crazy. Quote
selmir Posted June 21, 2008 Author Posted June 21, 2008 No. It's a limitation of the data structures that are used for interprocess communication by DVBViewer. We didn't expect someone to be that crazy. Hi, I use one computer as a DVB Server with several DVB-S cards. On another computer I run 8 instances of DVBViewer connected to DVB Server and use netstream plugin to stream 8 channels (I stream every channel on different IP address). Average CPU time on my computer (with 8 DVB Viewers - audio/video disable) is about 15%. It will be great if can be possible to run more than 8 instances from one machine. Whit this feature I think that will be possible to stream more than 20-30 channels from one computer. Quote
