alvox Posted June 21, 2008 Posted June 21, 2008 (edited) I have both TT-3600 and TT-1500c on the same box. When I run DVBV my cable card is not initializing and the sat card is working properly. In order to initialize the cable card in DVBV I have to run Technotrend's BDA-APP first. Tested with 12 and 19 BDA driver versions. support.zip Edited June 21, 2008 by alvox Quote
alvox Posted September 27, 2008 Author Posted September 27, 2008 Hello there! Sorry for annoyance but: "Any chance to get response on this issue?" Quote
Lars_MQ Posted September 27, 2008 Posted September 27, 2008 try deleting the hardware.xml to get a default one. And rename the plugins folder to plugins1 Quote
alvox Posted October 7, 2008 Author Posted October 7, 2008 hardware.xml not found on disk C: !? Quote
Tjod Posted October 7, 2008 Posted October 7, 2008 In the DVBViewer About > Configuration folder than clos the DVBViewer and deleting the hardware.xml. Quote
alvox Posted October 11, 2008 Author Posted October 11, 2008 Thanks for your suggestions. Not helped in my situation. But, it's resolved by defining different group (A, B, C) for every card in HW and channels configuration. Quote
