In DVBViewer 3.9.4 doesn’t work Raw-commands DiseqC 1.1 / DiseqC 1.2
brildi
Hello,
For example,
[E0 10 38 F4] W244 [E0 10 39 F4] - (Raw DiseqC 1.0 + Raw DiseqC 1.1)
[E0 10 38 FC] W244 [E0 31 6B 02] - (Raw DiseqC 1.0 + Raw DiseqC 1.2 (Command to fix position on motor))
[E0 10 38 FC] W244 [E0 31 6E E3 ED] - (Raw DiseqC 1.0 + Raw DiseqC 1.2 (Command USALS))
Function «Use positioner» that automatically generate Raw-command DiseqC 1.2 doesn’t work also.
But DVBViewer 3.8.0 understands all abovementioned commands.
Card?
tt s2-3200
BDA 5.0.0.19
Edited by brildi
most likely you did not install all needed. please post support.zip
Unfortunately, I’m not using computer with DVBViewer at this moment. I can send you support.zip file at today's evening.
Thanks, in folder DVBViewer was not a file ttBdaDrvApi_Dll.dll
