caltacha Posted June 24, 2008 Posted June 24, 2008 I run DVBViewer from a PC in the U.K. with no internet connection. From another PC I downloaded an XMLTV epg file using the XMLTV GUI program (The file is in .xml format from the Radio Times). How can I get DVBViewer to access this file when I press the epg button in DVBViewer? I have placed the file in the same folder as DVBViewer.EXE, I have also checked the "DO NOT RECEIVE EPG DATA" box in SETTINGS>OPTIONS>EPG/Teletext but the epg window remains blank! support.rar Quote
Tjod Posted June 24, 2008 Posted June 24, 2008 Tay Auto Import XMLTV http://www.DVBViewer.info/forum/index.php?...st&p=197074 Quote
caltacha Posted June 24, 2008 Author Posted June 24, 2008 Tay Auto Import XMLTVhttp://www.DVBViewer.info/forum/index.php?...st&p=197074 I tried Auto Import XMLTV unsuccessfully from another computer that does NOT have DVBViewer installed. Does'nt Auto Import XMLTV have to be used on a PC that has both an internet connection and DVBViewer installed? Quote
Tjod Posted June 24, 2008 Posted June 24, 2008 With Auto Import XMLTV you do not need a Internet connection. You only need DVBViewer installed to import XMLTV xml files. A norther possibility is XMLTV Importer from the Members Section. Quote
Gioxy Posted June 24, 2008 Posted June 24, 2008 (edited) I tried Auto Import XMLTV unsuccessfully from another computer that does NOT have DVBViewer installed Auto Import XMLTV can't work without DVBViewer... it need DVBViewer to import the data... (edit: sorry, I saw Tjod's same answer only once sended mine...) Edited June 24, 2008 by Gioxy Quote
