PeterausMelbourne Posted June 25, 2008 Posted June 25, 2008 Hi Everyone, I was just watching telly through DVBViewer and all of a sudden it turned into DVBViewer Media Center. Which I have a remote control for. Then it turned itself back into DVBViewer normal. I cannto find any option to do this. Was it a sneak preview. Can anyone tellme how to turn it on as it would make Vista worth having. Regards Peter Quote
Lars_MQ Posted June 25, 2008 Posted June 25, 2008 it did what? you mean the OSD? Did you press the ESC key? Quote
PeterausMelbourne Posted June 25, 2008 Author Posted June 25, 2008 it did what? you mean the OSD? Did you press the ESC key? YES Thats it. I must have pressed the Escape key. But now when I Installed the new version I have lost some of my channels. I had a post here before on how to get them back. But I cannot find it. The problem was that I cannot find SBS or channel 9 when I do a channel scan in Australia. I had to fiddle with Australia.ini but I dont know which one as Vista keeps several. Where are the old posts kept? Quote
Lars_MQ Posted June 25, 2008 Posted June 25, 2008 Maybe someone will now post a transponder ini for his region to be included in the next version... Quote
PeterausMelbourne Posted June 25, 2008 Author Posted June 25, 2008 Maybe someone will now post a transponder ini for his region to be included in the next version... OK 2 out of 2. Here is the last question. I dont get any sound but I get picture for the HD channels in Australia. I am running Vista SP 1 using a 7160 BDA DVBT Tuner with the latest version of DVBViewer. Any suggestions. Quote
Kuni Posted June 26, 2008 Posted June 26, 2008 YES Thats it. I must have pressed the Escape key. But now when I Installed the new version I have lost some of my channels.I had a post here before on how to get them back. But I cannot find it. The problem was that I cannot find SBS or channel 9 when I do a channel scan in Australia. I had to fiddle with Australia.ini but I dont know which one as Vista keeps several. Where are the old posts kept? Oi, I already posted how to overcome this problem when you first had it some months ago.... Search for posts from me.. Quote
