How to stop recording by pressing button on remote
jeppo77
Hi
Might be a stupid question but I havent figured out how to stop a recording once it's busy, by just pressing a button on the remote. There's "STOP" under the PVR section in the input menu, but it doesn't stop ongoing recording. the only way I can stop it now is by using the mouse and clicking on the record symbol in the statusbar below the screen...
thanks
If you refer to a recording started by the Rec remote key, simply press another time the Rec remote key... :)
