How to close the teletext window with remote?
tkotilah
Simple question, but in inputs section I could not find a proper entry for closing the teletext window.
Using the OSD teletext it works, but there I can't use the number keys for page selection ;-(
Pleas no Crossposting, it is ok to ask in the same Topic.
In most cases not possible. It is only possible if the Remote emulate the Esc key from the keyboard.
Maybe this should go to "Features requested", as having a teletex-window, that you can not close is most unusable. I just wonder, why the key opening teletext does not close it. After all DVBViewer is a TV ;-)
