Klaus_1250 Posted June 29, 2008 Posted June 29, 2008 (edited) I'm wondering if it is possible for DVBViewer to apply some sort of BT.601 / BT.701 colour conversion, as can be done with Media Players like MPC(-HC). Currently, if I watch Netherlands 1 SD, colors look washed out/bland compared to Netherlands 1 HD. Even the black on NL1 SD doesn't seem really black. Awkwardly enough, when I put the image of Netherlands 1 SD full screen on a 5:4 monitor, the black bars around the image aren't black either. But they are on NL1 HD??? Is there any way to fix this? Codecs used are both from Cyberlink. Graphics card is HD3850 AGP with Catalyst 8.6 Edited June 29, 2008 by Klaus_1250 Quote
hdv Posted June 29, 2008 Posted June 29, 2008 Hello, Codecs used are both from Cyberlink.in the setting from CyberLink Decoder you can change the colors. DVBViewer -> View -> Filters -> CyberLink... PS: the controller only available if DXVA is off. Quote
