Neo Tsui Posted June 29, 2008 Posted June 29, 2008 Dear sir/madam, I found that there's an known record in the "Timer" I want to remove it but the button "Remove" is disabled. (See attached) Thx. Rgds, Neo~~~ Quote
Lars_MQ Posted June 29, 2008 Posted June 29, 2008 could you please send me your channellist (channels.dat) and the timerfile (timers.xml) via PM, so I can try to reproduce it here? Quote
Neo Tsui Posted June 29, 2008 Author Posted June 29, 2008 could you please send me your channellist (channels.dat) and the timerfile (timers.xml) via PM, so I can try to reproduce it here? Where can I get these 2 files ? Thx. Quote
Lars_MQ Posted June 29, 2008 Posted June 29, 2008 in DVBViewer: mainmenu -> info -> configfolder In the DVBViewer programgroup -> userdatafolder Quote
Neo Tsui Posted June 29, 2008 Author Posted June 29, 2008 in DVBViewer: mainmenu -> info -> configfolderIn the DVBViewer programgroup -> userdatafolder Sorry, Lars_MQ, I don't know how to send attachments via PM. Below pls find 2 files. channels.dat.txt timers.xml Thx. Quote
Lars_MQ Posted June 29, 2008 Posted June 29, 2008 OK I found the problem. As a shortterm solution for you: - close DVBViewer. - Open the timers.xml with notepad - remove the following line (careful!) <entry name="2">;;30.12.1899;15:27:00;15:28:00;4;;0;true;false</entry> the whole line. - save the file. Quote
