fxv300 Posted June 30, 2008 Posted June 30, 2008 Hi, Have just installed 3.9.4 and most thing work fine. I am struggling to find a way to add my Terrestial feed into the DVBViewer. The terrestial device I have is a Pinnacle Sytems USB based device and works fine with its' own app (Vista 32bit). I have also noticed that HD programmes do not record in .mpg format but .ts (Is this a restriction). SD TV does record OK in .mpg format. I am using an HD3870 Ati Radeon GPU. So many options for tweaking purposes. Is there any guidance on what options to choose from the many that you can use (in this case connected to a PC monitor directly - monitor is 1920p LG24") Occasionally when I resize the screen it get into some weird mode and is streched etc. Is there a quick way to go back to 100% Zoom with a keystoke - I presume you can programme these somewhere. Cheers Frank Quote
