DrViewer Posted June 30, 2008 Posted June 30, 2008 (edited) Loving DVBViewer just have a minor niggle... Ive made sure Ive selected 16:9, but when I view any channel, It shouws the image as 4:3, then has the first quater of the screen repeated, stuck on the right side of the 4:3 image... Ive gone through the settings, and cant seem to find anything to resolve it... Got the latest 3.9.4 version... Thanks Edited June 30, 2008 by DrViewer Quote
DrViewer Posted July 1, 2008 Author Posted July 1, 2008 (edited) Anyone... its making the prgrammes unwatchable...??? ITs very distracting!! Edited July 1, 2008 by DrViewer Quote
pinbot Posted July 1, 2008 Posted July 1, 2008 If you are yousing VMR7 or VMR 9 try the following: Options ->DirectX, make shure "Use VMR Fix is tagged", click "ok" or Change from VMR to OverlayMixer If the above does´nt work, it could be a faulty drive or Codec. In this case please post your "support.zip" Greetz Pinbot Quote
DrViewer Posted July 2, 2008 Author Posted July 2, 2008 Thank you..that resolved the problem... Quote
