ristohopea Posted July 1, 2008 Posted July 1, 2008 HEi I installed windows vista sp1 home edition and also installed the latest 3.9.4.0 from DVBViewer what I use in combination with the TT3200 CI. Previously I was able to view all the channels via the payed subscription of TV Vlaanderen. Lately they changed the frequencies to the astra 19.2 12721 22000 H. I should be able to view: EEN Ketnet/Canvas VTM 2BE ..... For one or another reason I allways get that my subscribption isnt valide when I select EEN or KEtnes/Canvas.... VTM, 2BE etc are working fine even they are on the same settings.... So I allways get error "subscription card isnt valide for this channel" When I add the card to my settopbox it all works fine. I removed DVBViewer installed it again but no luck I checked all latest BDA drivers etc..no luck.. HEre you can find the support.zip info: Technotrend 3200 CI BDA driver 5.0.0.19 Asus P5K Intel 775 Intel Core2Duo E8200 ATI Radeon HD 2600XT 8.421.0.0 Hope someone can help... Thanks Br Risto support.zip Quote
ristohopea Posted July 7, 2008 Author Posted July 7, 2008 Nobody who can give any help or indication? Risto Quote
hercum Posted November 28, 2008 Posted November 28, 2008 It seems that I'm having the same problem but I know what's causing it. I had this problem on my tv too, just needed to download new software for the receiver and it worked again. TV Vlaanderen told me that they changed to mediaguard 3 encryption, this is the problem (I think). Everything works fine just Eén and Canvas don't work, very irritating. btw I'm using a Skystar HD with original TV Vlaanderen cam and smartcard + these channels work just fine in technisat tv center. All the settings are the same (freq. vpid, apid,...everything) I even tried old settings. I have been working on this one for 3 full days, any help would be much appreciated. support.zip Quote
