CI module
I can't access to the menu of my powercam in the Common interface menu. I see that the commoninterface .exe is installed in subfolder of Firedtv install and not in any subfolder of DVBViewer (If I use firedtv viewer i can acces to the menu of my powercam).
How can I proceed to see the powercam menu in DVBViewer?
My config :
Windows vista SP1 X64
2 floppydtv (last upgrade drivers)
2 powercam HD 2.0
DVBViewer pro 3.9.1
the support report :
Digital Everywhere Support Report: (1. 0. 8. 0)
Generated on (Y/M/d): 2008.06.13
FireDTV / FloppyDTV devices:
devices found: 2
Status for device 1
Model : FloppyDTV S2
GUID : 0x00128724040007D7
HW Ver.: 01.24.04
FW Ver.: 1.0.1 Build 13440
Driver : 5.0.1
Frontend Status:
Sig.Str.: 77%, BER: 0
Locked : YES
CAM Module: PowerCam HD 2.0
Status for device 2
GUID : 0x00128724040007D9
HW Ver.: 01.24.04
Driver : 5.0.1
Frontend Status:
Sig.Str.: 100%, BER: 0
Locked : YES
Windows System Information:
OS Path: C:\Windows
OS Version:
Microsoft Windows Vista, Service Pack 1 (Build: 6001)
OHCI Controller:
Manufacturer: Texas Instruments
Description: Contrôleur hôte Texas Instruments IEEE 1394 compatible OHCI (Open Host Controller Interface)
MCE Plugin:
No Plugin Version found!
No Service found!
Program files path: 'C:\Program Files (x86)'
FireDTV Transponder List:
No Transponder Lists found!
FireDTV Tools:
No running FireDTV tools found
update to the current DVBViewer version. no support for old versions.
