maiso85 Posted July 3, 2008 Posted July 3, 2008 Bonjour, j'essaie de scanner le transpondeur de Arte HD mais je n'y arrive pas. Que faut-il faire ? (ZDF Vision: A new channel has started in DVB-S2 Clear: Arte HD (France) on 11361.75MHz, pol.H SR:22000 FEC:2/3 SID:11120 PID:6210[MPEG-4] /6221 German,6222 French. ) Quote
Tjod Posted July 3, 2008 Posted July 3, 2008 Pleas only English in the English Part from the board. Quote
hdv Posted July 3, 2008 Posted July 3, 2008 Hello, you need a new transponder.ini, the frequency 11361 MHz is new, and without the new list the DVBViewer can't know it and won't scan the frequency. But you can import this ini to receive the new arte HD -> arteHD.zip Quote
Snoopyseb Posted July 10, 2008 Posted July 10, 2008 Where do you put this ini file in DVBViewer? Thank you for your answer. Quote
Tjod Posted July 10, 2008 Posted July 10, 2008 In the Channel list editor click on Import and select the ini. Quote
