Klaus_1250 Posted July 4, 2008 Posted July 4, 2008 How do I set the Cyberlink-decoder to work in PAL-mode in stead of NTSC? I can't find an option anywhere :-( The ATi MPEG decoder does work correctly (e.g. de VMR Renderer properties shows it is working in 50Hz mode for interlaced material), but the Cyberlink MPEG2 decoder is working at 59.94Hz while source and output are 50Hz. Quote
trifon33 Posted July 5, 2008 Posted July 5, 2008 (edited) How do I set the Cyberlink-decoder to work in PAL-mode in stead of NTSC? I can't find an option anywhere :-( The ATi MPEG decoder does work correctly (e.g. de VMR Renderer properties shows it is working in 50Hz mode for interlaced material), but the Cyberlink MPEG2 decoder is working at 59.94Hz while source and output are 50Hz. ??????????????????????????? Output 50Hz???? Graphic card TV output???? The video filter can't work in NTSC when the source is PAL 50Hz in Europe. In case of US graphic card, one can get NTSC from the TV output; but the video filter is the same anyway. There is no specific setting. Please give more inputs regarding yout PC and what you do exactly. Edited July 5, 2008 by trifon33 Quote
Klaus_1250 Posted July 5, 2008 Author Posted July 5, 2008 Sorry, the problem is the following. When using the Cyberlink codec, it is deinterlacing like the source material is NTSC, while in fact, the source material is PAL. See: Quote
