Danielem Posted July 4, 2008 Posted July 4, 2008 Hello, i really think this is a great program, a friend of mine let me tried his 3.9.4 version on my Windows Vista, before to decide to buy it, but i cannot see any channel... I have a BDA DVB-T device, i can scan transponders without problems but when i click on a channel in channel list, it gives me this error: "Cannot load source filter, error: 0x80040154". This even if i try to use any codec i've installed and with any setting about renders etc etc. On windows xp, no problem and with Windows Vista other programs work too... Do you think a solution can be found for this problem? Thanks in advance. Quote
Danielem Posted July 4, 2008 Author Posted July 4, 2008 I run regfilter.exe ( i read a similar old post ) and now it works everything. But why this happen? Quote
Franckx Posted July 29, 2008 Posted July 29, 2008 Hi, im having the same problem, Windows Vista, channels scanned right but no video or sound... where did you found the regfilter.exe file? how you fixed this? Thanks in advance for your help. Quote
Lars_MQ Posted July 29, 2008 Posted July 29, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
