patti Posted July 5, 2008 Posted July 5, 2008 (edited) Hello, when I sort my recordings by date in the OSD recordings window they are not sorted by date but first by channel and then each channel's recordings are sorted by date. Is there a way to make them sorted by date only (like it was earlier) because if you do not remember the channel your recording was recorded from then finding what you are looking for is pain. After all, sorting is there to help you to find what you are looking for and at the moment date sorting does not do that. My DVBViewer version is 3.9.4.0 and I first noticed this behaviour after I had updated to this version. I haven't found an option to change this behaviour. Thanks Edited July 5, 2008 by patti Quote
Lars_MQ Posted July 5, 2008 Posted July 5, 2008 works for me . Are you sure you use the right sorting? Quote
patti Posted July 5, 2008 Author Posted July 5, 2008 works for me . Are you sure you use the right sorting? Hey, now that you asked it, no I didn't use the right sorting! This is because in other places in OSD the button label (the red button in this case) shows the function that happens when you press that button. With sorting the button's label shows what is the current sorting order! This is illogical. But sorting works Quote
