Bad HTTP 401 header
Michael C
This bug applies to all versions of Recording Service and Web Frontend. It affects the Apple Safari browser (Mac, Windows and iPhone) not to be able to access the web site.
Before a web client authenticates, the web server returns:
HTTP/1.1 401 Unauthorized
WWW-Authenticate: Basic Realm=DVBViewerContent-Type: text/html
Content-Length: 157
A carriage return character is missing. The correct header should be:
Content-Length: 157
Just installed the DVBViewer Recording Service 1.4.2.0. But the problem still persists. The header is still faulty.
Content-Length: 157
fixed.
:( I did fix it, but the compiler decided to use an old version of the file ;)
This time I made sure it really uses the right file. Please download again, I uploaded a fixed version.
Excellent! I can finally login into the mobile edition on my iPhone Safari now. Thanks!
However, the layout does not look good on the iPhone.
post-61061-1215880979_thumb.png.
It looked better after I added the following meta tag to the template files under "SVCweb\mobi":
<meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=1;"/>
So with the tag in the template files, you can then claim the mobile edition is optimized for the iPhone! (though there is still room to improve.)
;) I did fix it, but the compiler decided to use an old version of the file :)
Coool, now i got it also working here with my Ipod. Do you know the IUI (http://code.google.com/p/iui/) Project? I already started working on a touch design, but since my html skills are lousy i dropped the interest o:)
Peter
@Lars_MQ
Hummm, it seems that the compiler decided also to use the old versions of the languages files... ;)
o:)
Nope that was me o:) I really need a secretary for keeping track of everything. Sorry, I'll fix it as soon as possible.
Hello everybody,
where can I download this new version? Version 1.4.4.0 and 1.4.9.0 (beta) don't work for me on the iPhone (401 Error).
Best regards,
Arno
:angry: Sorry, I mixed up the web interface and the recording service.
Is there a version of the web interface available which corrects the 401-bug with the iPhone?
I will update the web interface for the DVBViewer this weekend and promoted it from beta to release with this little fix integrated.
