Chris G Posted July 6, 2008 Posted July 6, 2008 Operating System: Vista Home Premium TV Card: Hauppauge HVR-4000 Hi, Please excuse my ignorance. I have just built a media centre and can’t get Vista MCE to display HD Channels (all other channels are displayed with no problems) hence why I have bought DVBViewer. When DVBViewer installs it shows the hardware as - Hauppauge WinTv 88x DVB-S/S2 Tuner/Decoder The scan channels section of the install just seems to hang. After completing the install and selecting scan channels I keep getting “NO HARDWARE AVAILABLE!” In the hardware section there is only one Hauppauge devise to select. Again – please excuse my ignorance but what part of the install have I done wrong ? Regards Chris. Quote
Chris G Posted July 7, 2008 Author Posted July 7, 2008 Thanks to every one who has contacted me. The problem was rectified by changing the registry settings. Quote
pacopaco78 Posted August 12, 2008 Posted August 12, 2008 (edited) Thanks to every one who has contacted me. The problem was rectified by changing the registry settings. Hi, Please could anyone tell me how can i to do work my Hauppaueg HVR-4000 with DVBViewer Pro, because i think i have the same problem. Thanks Sorry, i just read this: Version BETA 3.9.4.10 ---------------------- * New: Hybrid Tuner Support (HVR & Co) does work now. Please delete your hardware.xml in the userdata folder, so the DVBViewer does a new hardware scan. So, i'll try to install this beta and then... Edited August 12, 2008 by pacopaco78 Quote
