I have just upgraded from Vista to XP
PeterausMelbourne
Hi Everyone,
I have just upgraded from Windows Vista to XP SP2.
When I run DVB Viewwer3.9.4.0 i get the following error
Cannot render Mediafile/Ouput Pin, error:0x80040218 No...bination of filters could be found to render the stream
The when I press enter I get another error.
No software MPEG2 decoders found.
Can someone please help me to fix the problem, Please dont use techy speak on me as I wont understnad it.
I am not going back to Vista.
I forgot to mention that on the channels i get sound but no picture. ;)
Regards
Peter
Edited by PeterausMelbourne
well there is no decoder installed, it can't work. First install suitable decoders (maybe from the install cd of your dvb-card) then it will work.
I didnt get a CD with it just the driver pre-installed. I have looked all over the Internet and cannot find it. I am very dissapointed.
Hello,
you don't have any DVD-Player software, like PowerDVD or WinDVD ?
A Trial or Demo will work too.
:) Exactly expresses my opinion about Vista. However, XP doesn't provide a MPEG2 decoder, that's the source of the trouble.
You may want to try freeware decoders - here you'll get some hints. Or install ffdshow. It's working pretty well with TV/recordings (not DVD playback). Make sure that MPEG2 is enabled in the ffdshow Video Decoder Configuration (see start menu), Codecs section. Set it to libmpeg2. And switch deinterlacing on.
If there is more than one MPEG2 decoder installed, go to Options -> DirectX in DVBViewer and select which one shall be used.
Oh wow that works very well. Now I have sound in my HD channels as well.
XP is the best thing ever invented well done Microsoft :bounce:
