flanagann Posted July 7, 2008 Posted July 7, 2008 Hello! I'm starting to use DVBViewer and I was wondering if recording can be started from command line (DOS or Unix). I've read that a feature called 'DVB Task Scheduler Plugin' is availabe but I don't know if it's the same I'm asking for. What I want to do is create a batch script to start the recordings; this batch could be scheduled in Windows system as a scheduled task. Thanks! Quote
Tjod Posted July 7, 2008 Posted July 7, 2008 To programme recordings via Command line you need "TV Genial + CMDline 1.1" (Members section). DVB Task Scheduler builds windows Tasks to start the DVBViewer for Recordings. If you only want recording Recordingservice Beta is the better solution (works although with "TV Genial + CMDline 1.1"). Quote
