chrisgeller Posted July 8, 2008 Posted July 8, 2008 Hi Still very new to DVBViewer so apologies if I've missed something obvious. I use Timeline as the EPG viewer, but find it disappointing I can only see five channels. I've got a 42" plasma so can fit on quite a few more. Is there any way to modify Timeline or use a different EPG that works nicely by remote. Quote
feixen Posted July 8, 2008 Posted July 8, 2008 I use Timeline as the EPG viewer, but find it disappointing I can only see five channels. as I read ... you mean the OsD. tell us ... please ... which one you currently use. the skinns can be edit by osdskinner [download im members area] feel free to add more rows for timeline-page. otherwise ... Menu >> DVBViewer >> EPG-Window showing you more channels. Quote
chrisgeller Posted July 9, 2008 Author Posted July 9, 2008 as I read ... you mean the OsD. tell us ... please ... which one you currently use.the skinns can be edit by osdskinner [download im members area] feel free to add more rows for timeline-page. otherwise ... Menu >> DVBViewer >> EPG-Window showing you more channels. I know about the EPG-Window, but it looks pretty nasty on the TV and is difficult to use with a remote. Indeed - I'm using the OSD and then selecting Timeline. When you say "add more rows for the timeline page" how do I do that!?! That would solve the problem. Quote
Gioxy Posted July 10, 2008 Posted July 10, 2008 (edited) Feixen mean you can edit the OSD-skin with the "Skin Editor" you can find in this page (all in all not a absolute beginner task...) Or simply you can download a new OSD-Skin you can find in the "Skins" section of the Member area or in the OSD subforum... For your comfort I report here the number of row (alas channels) displayed in the "My EPG page" by some OSD-Skins (some of them can be a little incomplete in some other part); clicking on their names lead you to the relative download pages: Default = 5 row XIC3HDG43 = 5 row SimpleBlue = 5 row DVBHD-Blue2k7 = 6 row MGreyHD = 6 row TGreyHD = 7 row TXMasPAL = 7 row Edited July 10, 2008 by Gioxy Quote
