ajr Posted July 11, 2008 Posted July 11, 2008 Hi, I have tried Transedit tool to check if I can get my tunercard working with DVBViewer. I have Windows Vista 64 Premium and my tuner card is Technotrend DVB-C Budget 1500. I have installed latest BDA driver's. Transedit finds the tunercard but it can't find any channels. I believe that my transponder list is correct and it should work with that. Is there someone that has found channels correctly with vista 64 and Transedit? Is there some settings that I have to check? Thanks ! Quote
feixen Posted July 14, 2008 Posted July 14, 2008 hello ... my tuner card is Technotrend DVB-C Budget 1500. I have installed latest BDA driver's. we hope, that your original software can tune all channels in your cable-network. Transedit finds the tunercard but it can't find any channels. I believe that my transponder list is correct and it should work with that. tell us ... which cable-provider you would be use? in which country? do works the blind scann? Quote
