Picture freezes on Vista but XP Pro OK
HakanK
Hello to everybody!
I am using skystar usb 2. I installed DVBViewer everything seemed fine. I open up a channel started watching TV. After a while channels started to freeze.No sound no picture. I closed the program restarted again, no picture no sound. So restarted my laptop, DVBViewer works fine again for awhile. I watch TV for about half an hour and again same thing happens. Here is what I did :
uninstalled nvidia drivers and reinstalled updated ones - doesnot work
updated skystar usb 2 drivers to 4.4.3 (latest) - doesnot work
uninstalled nvidia drivers and used microsoft drivers - doesnot work
installed NVİDİA decoder - doesnot work
used cyberlink decoder - doesnot work
played around evr-vmr7-vmr9 renderers -doesnot work
ffdshow decoder-doesnot work
run program in winXP pro compatible mode - doesnot work
you see I have done pretty much everything but the result is same.
Any ideas I should think?
p.s. skystar usb 2 and DVBViewer pro 3.9.4 works just fine but on vista ??????
