Bruciebaby12 Posted July 12, 2008 Posted July 12, 2008 Hi and hello everone and all is going well so far. Just a couple of questions. I was using PowerCinema before but i found it a bit clunky and prone to crashing. I was also using the remote that came with the WinTV-Nova-HD-S2 card. DVBViewer seems much more intuitive and easier to use but the remote doesn't work with it. Also I have seen a epg plugin, how do I import plugins? I have only just began tinkering about with DVBViewer and don't want to do anything to crash it. I've got all the channels listed and they all display well. If this has been answered before please forgive me, I couldn't even find the search function in this forum! any suggestions please. Oh, please be patient with me as I'm an old man (65) and probably not so cool with all the procedures. Quote
habibm Posted July 14, 2008 Posted July 14, 2008 Hi and hello everone and all is going well so far. Just a couple of questions. I was using PowerCinema before but i found it a bit clunky and prone to crashing. I was also using the remote that came with the WinTV-Nova-HD-S2 card. DVBViewer seems much more intuitive and easier to use but the remote doesn't work with it. Also I have seen a epg plugin, how do I import plugins? I have only just began tinkering about with DVBViewer and don't want to do anything to crash it. I've got all the channels listed and they all display well. If this has been answered before please forgive me, I couldn't even find the search function in this forum! any suggestions please. Oh, please be patient with me as I'm an old man (65) and probably not so cool with all the procedures. The Hauppauge 45 button remote control can be programmed to generate keyboard shortcuts e.g. pressing CTRL + X to close an application would be {ctrl}x, you simply edit the irremote.ini file in the Windows folder. The way to configure DVBViewer with keyboard shortcuts is to assign you own ones. In DVBViewer go to 'Settings' menu, Options and then Input on the left hand side, you have to click the Learn button and then press the key sequence you want use, it will record it. Below between the speech marks is my irremote.ini file. " ; This is only for the 45 button Hauppauge remote control and using IR32 software [Remote] RepeatDelay=3 ; Button "name" lookup table [systemCode] 30=HCWPVR2 ; Hauppauge 45 button remote. The numbers on the left are what is read by IR32 software when you press the labelled button on the remote control. [HCWPVR2] 0=0 1=1 2=2 3=3 4=4 5=5 6=6 7=7 8=8 9=9 10=TEXT 11=RED 12=RADIO 13=MENU 14=SUBCC 15=MUTE 16=VOLUP 17=VOLDOWN 18=CHNLPREV 20=NAVUP 21=NAVDOWN 22=NAVLEFT 23=NAVRIGHT 24=VIDEOS 25=MUSIC 26=PICTURES 27=GUIDE 28=TV 30=SKIPFWD 31=BACK 32=CHNLUP 33=CHNLDOWN 36=SKIPREV 37=OK 41=BLUE 46=GREEN 48=PAUSE 50=REWIND 52=FASTFWD 53=PLAY 54=STOP 55=REC 56=YELLOW 59=GO 61=GRNPOWER [Applications] DVBViewer= [DVBViewer] GRNPOWER={run(..\DVBViewer\DVBViewer.exe)} GO=n TV={shift}s VIDEOS={shift}a MUSIC={shift}n PICTURES={shift}k RADIO={shift}f GUIDE=e SUBCC={ctrl}x BACK={space} MENU={esc} NAVDOWN={down} NAVLEFT={left} NAVRIGHT={right} NAVUP={up} OK={enter} REC=r STOP=u PAUSE=t PLAY=y REWIND={shift}y FASTFWD={shift}u SKIPFWD=b SKIPREV=v MUTE=m VOLUP=q VOLDOWN=a CHNLUP=s CHNLDOWN=x CHNLPREV=l RED={f5} GREEN={f6} YELLOW={f7} BLUE={f8} TEXT={shift}e 0=0 1=1 2=2 3=3 4=4 5=5 6=6 7=7 8=8 9=9 " Quote
