Bug with aspect ratio
I'm new to this community so hopefully i make the things right. I have set my aspect ratio to "auto" and everytime the tv channel changes aspect ratio from 4:3 to 16:9 or vice versa the DVBViewer screen goes black. I can hear the sound tho. This usually happens when there is commercial break.
Think I had that too with EVR as video renderer. Manually set the aspect ratio through DVBViewer. After going into/out of fullscreen, video reappeared.
Well yeah, i have EVR as video renderer. It's the only one that works fine on my comp. VMR 9 shows the picture but it's little bit grainy. Is there anything i can do?
Bump. Would like to see if there are anything i can do to solve this.
Only work around it by pressing the rebuild graph button...
It's a evr bug brought to you by MS.
Okay thanks. I was hoping there would be solution for fixing this but i think i can manage with that.
