login365 Posted July 12, 2008 Posted July 12, 2008 I've just upgraded to Vista and installed the latest DVBViewer (3.9.4.0), which seems to be working fine after a fair bit of tweaking. The only problem im having now is that channels added to my Favourites wont tune, the only way I can view them is by opening the Channellist and selecting a channel. Has anyone else experienced this problem or able suggest a possible fix? Tia, Mike Quote
login365 Posted July 20, 2008 Author Posted July 20, 2008 I've removed DVBViewer and other software then re-installed and still experiencing problems. Its such a pain having to go through the channel list everytime to change channel! Has nobody else experienced this problem!? Quote
feixen Posted July 20, 2008 Posted July 20, 2008 if it yours possible ... please poste the file favourites.xml from your config-folder. otherwise is this helpfully ---> click copy it in main-directory >> execute it >> poste your support.zip Quote
