fxv1 Posted July 13, 2008 Posted July 13, 2008 Hi, I have a problem with screen format display.The problem only happens with the CoreAVC Video decoder. This is the with the latest version. http://www.coreavc.com/ When I use this codec the screen becomes uncontrollable. The programmed screen modes (for example 100%, 75% etc do not respond correctly). If I remove the codec the screen modes behave much better. I am not sure if the problem is with the CoreAVC codec or with the DVBViewer software. Have tried this with DVBViewer 3.9.4.0 and also with the latest BETA 3.9.4.25 I have tried this with a few different skins but for the test I used the default skin. I enclose support.zip and a screenshot. I have done rebuild graph many times and also tried all the screen formats from the menus. It would be useful to all your customers if some kind of detailed feedback regards this is provided as I have seen this mentioned in a few forums. Thanks in advance for your help. Quote
CiNcH Posted July 22, 2008 Posted July 22, 2008 (edited) Can't reproduce that here. Maybe the driver is too new for that hardware. Most of the time it is better to stop at some point updating graphics drivers as they may introduce problems with old hardware due to tweaks for new hardware. Also you should try a different video renderer. Edited July 22, 2008 by CiNcH Quote
fxv1 Posted July 22, 2008 Author Posted July 22, 2008 Can't reproduce that here. Maybe the driver is too new for that hardware. Most of the time it is better to stop at some point updating graphics drivers as they may introduce problems with old hardware due to tweaks for new hardware. Also you should try a different video renderer. I am trying the MediaTheatre codec now seems to behave better. Thanks Quote
fxv1 Posted July 22, 2008 Author Posted July 22, 2008 Can't reproduce that here. Maybe the driver is too new for that hardware. Most of the time it is better to stop at some point updating graphics drivers as they may introduce problems with old hardware due to tweaks for new hardware. Also you should try a different video renderer. Which Video renderer do you recommend, I am using Vista 32. Thanks Quote
CiNcH Posted July 22, 2008 Posted July 22, 2008 See here. Your support.zip seens outdated concerning your graphics hardware... Quote
