Picture freeze when changing channels
chrisgeller
Hi
I've noticed that when I change channels using the OSD Timeline EPG, the picture will very often freeze on the original channel, and take up to 20 seconds to switch to the new channel (although I can hear the sound OK).
This doesn't always happen - I suspect it's only when I'm changing transponder.
Any advice on how I can fix this?
Just to reply to my own question, I fixed this by turning off 'Fast Channel Change' in settings.
I have the same problem with DVBViewer 3.9.4 changing channels with EPG Timeline, but it doesn't go away by turning off "Fast Chanel Change". And it doesn't work trying to Rebuild Graph either. The only thing to do is to restart DVBViewer. Earlier DVBViewer version did freeze in the same manner but could be reset with Rebuilding the Graph at least. OS:WinXP
Somebody nows what to do?
