Gary Lam Posted July 14, 2008 Posted July 14, 2008 Can DVBV provide "Audio disabled" and "Video disabled" ? Thank you~ Quote
Tjod Posted July 14, 2008 Posted July 14, 2008 Options > Input > Add Group -> select the new Group > Add > Disable Audio > select Disable Audio > Add > OK select the new Group > Add > Disable Video > select Disable Video > Add > OK Quote
Gary Lam Posted July 14, 2008 Author Posted July 14, 2008 Options > Input > Add Group -> select the new Group > Add > Disable Audio > select Disable Audio > Add > OKselect the new Group > Add > Disable Video > select Disable Video > Add > OK I mean add them into the "View" menu Thanks Quote
