Changing number of seconds in jump +xx / -xx?
chrisgeller
Hi
I see this is stated in the settings as +xx/-xx, but is actually always 10 seconds. Is there any way to change this amount? Ideally I'd like it to jump forward 30 seconds and back 10 seconds (handiest for coping with adverts!)
If you pres the button multiple times you get bigger jumps.
But you can also charge the default values, by add
  <section name="Jumptime">
<entry name="0">10</entry>
<entry name="1">30</entry>
<entry name="2">60</entry>
<entry name="3">120</entry>
<entry name="4">300</entry>
<entry name="5">600</entry>
<entry name="6">900</entry>
<entry name="7">180</entry>
 </section>
in the setup.xml in the configuration folder (About > configuration folder) and edit the values (Tweaks).
