lyukas Posted July 15, 2008 Posted July 15, 2008 I have purchasesd a ss hd2 and the DVBViewer Pro (3.9.4). I would like your help in some problems; Some things referenced in the DVBViewer user manual are completely different in my installation: 1. The following files mentioned in the manual and the tweaks.txt file do no exist in the DVBViewer folder or in any other place in my computer: channels.dat and setup.xml. 2. In the input paragraph of the options window (manual para. 7) is stated: "Keyboard: The left side of the list presents the available DVBViewer functions. The right side contains the assigned keys. In order to modify an assignment, double-click the desired entry, and then press a key or a combination of keys (e.g. [Ctrl]+[Q])." When double-clicking the entry it does not let me edit the key. By the way the Edit button is disabled as well. I can scan transponders and receive channels. Please provide your comments. Quote
Tjod Posted July 15, 2008 Posted July 15, 2008 1. Thy are in the Configuration Folder (About > Configuration Folder in the DVBViewer). 2. Select a command > click on Learn > pres the key > click on Learn. This Manuel is vary old. It was updated the last time for DVBViewer Pro 3.1 (my first version ). A more up to date version is this, but although not really up to date. http://www.DVBViewer.com/en/index.php?page=manual Quote
lyukas Posted July 16, 2008 Author Posted July 16, 2008 1. Thy are in the Configuration Folder (About > Configuration Folder in the DVBViewer). 2. Select a command > click on Learn > pres the key > click on Learn. This Manuel is vary old. It was updated the last time for DVBViewer Pro 3.1 (my first version ). A more up to date version is this, but although not really up to date. http://www.DVBViewer.com/en/index.php?page=manual Thank you very mutch. I got complete answers to my questions. Quote
