Vista 32 sp1 + evr = "negative" images
Hello, I have installed Windows Vista sp1 32 bits, Dvbvieser 3.9.4, coreavc 1.7, ffdshow and Cyberlink powerdvd 7.3.3104a.
When I select the EVR renderer the screen sees in "negative". I have select or deselect all the options in Directx, use or not the auto selection of video and audio, etc. If I select de windows 9 render or another of the renders I see all ok, but I need the EVR for the H264 channels.
What happend?
Thanks.
most likely a graphcs card driver problem.
  • 3 weeks later...
Same problem here. OS is Vista x64SP1 with Technisat SS2HD. EVR works with normal chanells but not with HD channels. On the other side VMR9 works with HD but gives 1/4 of the picture on normal channels.
Support.zip in attachment.
Edited by newen
