Playing mp3 and Flac music files
bakerpr
I am sure that I have in the past been able to play mp3 music files using DVBViewer.
I can still play original cds but no go with other formats.
I am using the latest release 3.9.4.0 with spdif audio on vista.
Does anybody think its worth a reinstall and if so can I just overwrite the existing install
You need Direct Shaw Decoder for mp3 and Flac on your System. If thy are working it should work with DVBViewer to.
Which decoders would you advise. I have both cyberlink and Arcsoft for video duties.
Windows natively supports mp3 playback via DirectShow. If it doesn't work something has been damaged.
For flac see here - answered recently. BTW: How do you expect to survive in the information age without being able to use a search function? Evolution will sort you out mercilessly.
Installed FLAC decoder and now I can playback Flac music files fine but still no go with mp3.
Mp3 playback is fine in MPlayer and MPC but DVBViewer trys to use arcsoft HD audio decoder as the filter but no sound can be heard.
