Mark 64 Posted July 19, 2008 Posted July 19, 2008 The ability to order the channel list with LCN (logical channel number), in the same manner as a standard dvbt decoder (some other dvb programs do this). I think is very useful, especially in rescan. Best regards Quote
Valts Posted August 3, 2008 Posted August 3, 2008 Well not certain about LCN. Can only say that it would be nice to improve the way channel rescanning/update is handled. Since at the moment after rescan have to manually go over channels to see which have died (are non-bold) and remove them manually and not quite certain which new channels have been detected. Quote
toblerone Posted November 25, 2010 Posted November 25, 2010 lcn is useless, but is it possible to save that little number, for use eg in the channle editor export function? if it is needed is enough to export then sort using that value: so simple thanks in adv Quote
