johnnneyboy Posted July 20, 2008 Posted July 20, 2008 (edited) Hi all I'm using a technotrend 3200 in my pc. Used to use altdvb, but have purchased the CI addon for my technotrend, plus a diablo cam, and altdvb doesn't cater for them. I bought DVBViewer a couple of years ago, and had read good things about the CI working, so spent yesterday setting things up again. I was getting picture for 2-3 seconds, then it would freeze. Found out just now that if I deselect "Has CI module" in the options, my problem disappears. However, I do want to use the cam! With "Has CI module" ticked, I can go into the cam menu. Does anyone know a way around my problem? Am using 3.9.4 DVBViewer. Edit : added required info and support.zip file exact TV-card modell and useed driver version technotrend 3200 driver 4.4.10.18 type and chipset of the mainboard abit core 2 duo board graphics card and useed driver version winfast nvidia px8800 gt driver 6.14.11.6906 support.zip Edited July 20, 2008 by johnnneyboy Quote
Lars_MQ Posted July 20, 2008 Posted July 20, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
johnnneyboy Posted July 20, 2008 Author Posted July 20, 2008 Please post some more information:http://www.DVBViewer.info/forum/index.php?showtopic=2210 Hi Lars - additional info added Quote
Lars_MQ Posted July 20, 2008 Posted July 20, 2008 Do you use the original (very short) cable between card and CI module? Did you do a crosscheck with the technotrend app for the card, to make sure it's not a hardware related problem? Quote
johnnneyboy Posted July 20, 2008 Author Posted July 20, 2008 Do you use the original (very short) cable between card and CI module? Did you do a crosscheck with the technotrend app for the card, to make sure it's not a hardware related problem? Thanks for your reply Lars. Yes, I'm using the very short original cable (card and CI are in slots next to each other). I'm having a hard time getting the original technotrend app - I've lost my cd, and when I download this file: TT-Media Center 1.0.7.9 (12.12.2007) (Windows XP/Vista 32bit und 64bit) from: http://www.technotrend.com/2899/PC-Produkte.html I load setup but it says no hardware found I checked my driver and it was being described as skystar 2 HD - removed the device in hardware manager, and it does now show as technotrend 3200 bda, but still no luck Quote
