media keys don't work
And that's a bug report now? :(
Edited by CiNcH
The MCE remote control sends WM_APPCOMMAND messages, I think every media application should handle these messages out of the box with default values, reality is none does and the reason why is because none of the authors own a input device sending WM_APPCOMMAND, not even EvenGhost does support WM_APPCOMMAND. Microsoft MCE remote control is a very good product, I think it deserves to be supported.
It is still a feature request :( .
I found out there is a MCE remote plugin, some buttons have issues, for instance some buttons will lauch MS MediaCenter, volume buttons will change volume for both DVBViewer and the system. Is the source code of the plugin available? Who is the author?
