About EPG update problem
iHD
If my DVBViewer not close for a long time, the epg data cannot update normally,
but it is success when i close it and restart.
Any other method to reset the EPG data but no need close the program?
Thanks.
The epg is updated as soon as you tune a channel.
Do you by chance use the recording service? It does update the epgdata in the background but only if the viewer is not running.
i am not using recording service.
if the program can reset all the epg data
i think the problem can be fix.
There is no such thing as epg reset. Please explain in detail.
just my guess.
My usage is open a channel for a long time, but after few days. the EPG in some day will blank
i need close it and open it again. i just guess EPG data have some problem so that cannot updata.
I attached the EPG file. Please help to check
1. before restart the program, today epg is missed (24/Jul)
2. after restart the program. today epg is fine after restart.
epg1.rar
epg2.rar
