Is there a plugin for this?
LearningCurve
I would like to have DVBViewer record everything on a channel, and break each program out to its own file according to its epg name. I want to record everything on prime time (7:00pm-10:00pm) without setting individual timers, and I don't want one big file.
Is there a plug in or a way to do this?
Thanks!
Thanks Tjod,
I will take a look at EPGplus. Do you think it will play nicely with the recording service plugin?
Thanks again!
To run EPGplus you need to run DVBViewer. But when EPGplus has programed the Timer you can use the recording service for recording.
