EricB Posted July 25, 2008 Posted July 25, 2008 i am a hong kong user and i am using galaxy e7 receiver i found that i can't use and even map the remote on DVBViewer the remote works on TotalMedia incl. the ir.map file can anyone teach me how to make it compatible with DVBViewer / convert to a .remote file? ir.map.txt Quote
starfall Posted August 15, 2008 Posted August 15, 2008 i am a hong kong user and i am using galaxy e7 receiveri found that i can't use and even map the remote on DVBViewer the remote works on TotalMedia incl. the ir.map file can anyone teach me how to make it compatible with DVBViewer / convert to a .remote file? http://www.hkepc.com/forum/viewthread.php?tid=1030244 Quote
