almaster Posted July 25, 2008 Posted July 25, 2008 Hello. I've DVBViewer beta version 3.9.4.25. I've this filters for AC3: Microsoft MPEG-1/DD, Cyberlink Audio Wizard, Cyberlink Audio Decoder (PDVD8), Nero Audio Decoder 2. I've tried all the filters, but when watching channel with ac3 audio, i hear nothing. Any idea? Quote
Tjod Posted July 25, 2008 Posted July 25, 2008 Tay the AC3Filter http://ac3filter.net/project/1/releases Quote
pinbot Posted July 25, 2008 Posted July 25, 2008 (edited) Sure... Get ac3filter from http://ac3filter.net/ Read thru the manual, install and get happy Greetz Pinbot Ooops "Speedy Tjod" stroke again.... Edited July 25, 2008 by pinbot Quote
almaster Posted July 25, 2008 Author Posted July 25, 2008 Thanks all. This filter works and is superb!!!! Quote
zou5020 Posted August 4, 2008 Posted August 4, 2008 (edited) Hello. I've DVBViewer beta version 3.9.4.25. I've this filters for AC3: Microsoft MPEG-1/DD, Cyberlink Audio Wizard, Cyberlink Audio Decoder (PDVD8), Nero Audio Decoder 2. I've tried all the filters, but when watching channel with ac3 audio, i hear nothing. Any idea? Hi, My situation is almost same, but after I had used the AC3Filter 1.46, and still don't hear anything, any advice for me?thanks for your help in advance! Edited August 4, 2008 by zou5020 Quote
trifon33 Posted August 4, 2008 Posted August 4, 2008 Hi, My situation is almost same, but after I had used the AC3Filter 1.46, and still don't hear anything, any advice for me?thanks for your help in advance! Try to set correct paramters in Windows Control panel>>>audio or sound integrated control panel. THre must have been 6 or 8 chanels. Usualy, you can test all chanels. Some CAM need updates to work with encrypted chanels including AC3 Open video filter properties(Cyberlink is the most popular and OK) for correct setting. Hope that can be of any help Quote
zou5020 Posted August 5, 2008 Posted August 5, 2008 Try to set correct paramters in Windows Control panel>>>audio or sound integrated control panel. THre must have been 6 or 8 chanels. Usualy, you can test all chanels. Some CAM need updates to work with encrypted chanels including AC3 Open video filter properties(Cyberlink is the most popular and OK) for correct setting. Hope that can be of any help Thanks for your kindly and useful help! My problem had been solved, the reason for the issue is: I forgot to set the Audio type from MPEG to AC3. Quote
