Beem Posted July 27, 2008 Posted July 27, 2008 Some things that dont work for me Pehapps someone knows how to fix. Starting. When i launch DVBv. first time (after boot) i only get a black picture. I have to exit and re-launch to get it working. This goes for every channel even free to air. Im using a card reader and DVB-T (Boxer), and [removed]. On some channels (discovery) i get corrupted sound. But picture is fine. It sounds "speeded" Im using "extended desktop". The second monitor is a projector. If i exit DVBv. and start next day. It still is displayed at second monitor. Not that great. Because i dont have the projector running. [My cards is Happuage Nova-T USB2] § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "common interface" (CI) and the corresponding "common access module" (CAM) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. Quote
Lars_MQ Posted July 27, 2008 Posted July 27, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
balky Posted July 27, 2008 Posted July 27, 2008 Hi, I experienced the same issue with CNN, what I did was to check the detect audio format button under options - directX. Maybe this can help you as well. cheers!!! Quote
Beem Posted July 27, 2008 Author Posted July 27, 2008 Hi,I experienced the same issue with CNN, what I did was to check the detect audio format button under options - directX. Maybe this can help you as well. cheers!!! I have got the Audio to work on Discovery now! Checked that button and changed audio decoder to "InterVideo NonCSS Audio Decoder for Hauppauge" Quote
Lars_MQ Posted July 27, 2008 Posted July 27, 2008 Well installing the decoder which came with your dvb-device could help also. Nero decoder are not suited for dvb. And intervideo is also not the best choice. Quote
