Griga Posted August 1, 2008 Posted August 1, 2008 If someone is interested... a new FTA HD channel has appeared on Hotbird 13° East: Name: m2 HD Provider: Magyar Televízió Video/Audio Format: H.264 1920 x 1088 / MPEG Audio 384 kbps Frequency: 12130 MHz Polarisation: H Symbolrate: 27500 FEC: 3/4 Modulation System: DVB-S (no DVB-S2 device required!) Service ID: 15551 Video/PCR PID: 1100 Audio PID: 1101 Teletext PID: 110 (not yet available) PMT PID: 50 Transportstream ID: 7100 ...currently broadcasting 4:3 embedded in 16:9, no true HD. Please note: The new transponder (frequency) is missing in DVBViewer/TransEdit transponder lists. It has to be added manually by using TransEdit, otherwise a Hotbird scan won't find it. Quote
Balazs Posted August 7, 2008 Posted August 7, 2008 Hi Griga, I have the following problem with this Channel: Using Cyberlink (PVDVD 8) codec, the video is jerky. (audio OK) Using any other codecs(MainConcept, CoreAVC etc.) on this channel, it works smoothly. Of course with Cyberlink, I could see any other HD channels without any problem As I checked, using Cyberlink on other HD channels GPU load is around 20%. If I try to view this Channel(M2 HD on Hotbird) with Cyberlink my GPU load is 0% So, it seems that on this channel Cyberlink "can not pass" the load to GPU Do you(or anybody else) have any idea what could be the reason of jerky video under Cyberlink ? My config: MB: P5K SE CPU: Intel 2,4 GHz (Core2 Quad, Q6600) Memory: 2 GB 800MHz RAM VGA: ATI HD3870 512MB GDDR4 Tuner: Hauppauge HVR-4000, SkyStar HD2 Standalone tuner: Manhattan Plaza XT-F OP125 Gibertini, Inverto Pro LNB, Andrews feedhorn, Jaeger 1224 H-H motor, 45m koax I'm using DVBViewer Pro latest version Best regards, Balazs Quote
Balazs Posted August 10, 2008 Posted August 10, 2008 The provider changed something and now it's OK ! Balazs Quote
