bsod Posted August 2, 2008 Posted August 2, 2008 Hello and thank you for your great program! I would like to know is it possible to sort (or rename) finished recordings within OSD? Currently, as my Vista's regional settings are set to Finnish, recordings are listed as follows: 13.05 23:59 progname-1 channel-1 20.03 23:59 progname-2 channel-2 . . . 25.06 23:59 progname-n channel-n (the format is "day.month hour:minute progname channel") Apparently entries are sorted from left to right using standard numeric sort algorithm as sort order seem to be day -> month -> progname -> channel. But is it possible to sort (or rename) them using standard ISO 8601 date format YYYY-MM-DD so that they would sort correctly according to date when recordings were made? I have already changed file name format from GUI, but it didn't affect recordings list in OSD. Quote
