DVB S2 3200+CAM Viaccess red FTA to encrypted chanel issue
trifon33
Hi folks,
When chanel change, I found some issue from FTA chanels to encrypted ones. The EPG says I have switched to the requested chanel but too long time to get the picture or sometime nothing! Restart the graph does not make any good.
Sometime, I need to restart DVBViewer 3.9.4.0 with Technotrend DLL + Visual C 2005 + Winlirc + ATI remote
THis is one very old issue already mentionned not solved with DVBViewer updated version.
It look like DVBV needs to reinitialize the CAM in that situation. Evrything is OK from encrypted chanels to another.
The issue does not occur with bundled TT Media Center.
Windows XP SP3
TT DVB S2 3200 driver 5.0.0.19
CAM VIaccess Red with firmware updated
Please help.
Hi Trifon,
Me to, I cant get Viaccess Red working correctly in my CI budget modified, the CAM seem crash or the CI controller seem lost connection to the CAM.
Because I use Smartwi, I have suspeded that the source of the problem is the overcurrent consumed by the SmartWi.
Now I use Powercam Pro without any problem in the same condition.
Hi Trifon,
Thanks Dadag, I suspected the Viaccess red CAM too.
I have tested the DVBSHOP TV(DVBViewer engine).
I can say there is no chanel change FTA to encrypted isue with the Viaccess CAM.
I have changed the ttBdaDrvApi_Dll.dll(version 1.0.1.14 downloaded with 3.9.4.0. for the newer version 1.0.1.15 that come along with DVBSHOP TV.
I am not sure that inprove things. The issue appears ramdomly.
