dmcq Posted August 4, 2008 Posted August 4, 2008 With ITVHD PMT and Service PIDs set to 0, the channel displays, records and plays back without a problem. However the resultant file has non-standard PIDs and won't play in any other application nor can it be edited. Does anyone know of an applet that can reset the relevant PIDs so that the file becomes standard HD TS spec please? Don Quote
Derrick Posted August 4, 2008 Posted August 4, 2008 ..nothing wrong with the pids. It's the stream type that causes problems but the DVBViewer puts it right Quote
dmcq Posted August 4, 2008 Author Posted August 4, 2008 Derrick Sorry for the wrong term. So does anyone know an app that can parse the file so that it comes out as a standard .TS file please. Quote
Tjod Posted August 4, 2008 Posted August 4, 2008 If you record with the current DVBViewer GE or the DVBViewer Pro Beta it should be work. New: Recording of ITV HD: The wrong videodescriptor is automatically adjusted. http://www.DVBViewer.info/forum/index.php?showtopic=27719 But i don't know how to fix this in existing recordings. Quote
dmcq Posted August 4, 2008 Author Posted August 4, 2008 Tjod Thanks. So the 3.9.4.10 beta solves this, thats great, so a recording made with DB Viewer should then play back in, say, PowerDVD 8? When do you think this will go mainstream as I see that the advice is that only advanced users should use the beta? Don Quote
Tjod Posted August 4, 2008 Posted August 4, 2008 so a recording made with DVBViewer should then play back in, say, PowerDVD 8?I think so, but i could not restive ITV HD so i cold not test it. When do you think this will go mainstreamDon't know. as I see that the advice is that only advanced users should use the beta?Ther are no knowen issue with curent Beta 3.9.4.25 is usebel (but read the beta readme.txt).But you can all though use DVBViewer GE 2.5.0 for recording ITV HD. Install this version in a separate folder and delt the Deutsch.lng to get a English interface. Quote
dmcq Posted August 4, 2008 Author Posted August 4, 2008 Tjod Thanks. I'm going to update to the beta to see if the ITVHD problem is solved. I've read the beta install notes which are fairly clear but I just want to check. Starting with a 3.9.4.0 Backup the recorder directory - DVBViewer Backup the program directory - c:\program files\DVBViewer (in my case) Expand DVBViewer 3.9.4.25beta.zip - then copy into c:\program files\DVBViewer (in my case) Restart. Is that right please? Thanks Don Quote
Tjod Posted August 4, 2008 Posted August 4, 2008 Backup the recorder directory - DVBViewerA Backup is good but not relay necessary. You miss this: Make a Backup of your data folder.To find the Location in the DVBViewer > About > Config Folder. Quote
dmcq Posted August 4, 2008 Author Posted August 4, 2008 (edited) Tjod Done that App now identifies itself as .25 beta. However behaviour is exactly as before. Should I be returning the PIDs to their original values? Do I need to do a complete retune? Do I still need to import the ITVHD.ini file? Again thanks Don Edited August 4, 2008 by dmcq Quote
Lars_MQ Posted August 4, 2008 Posted August 4, 2008 Should I be returning the PIDs to their original values? Yes. best rescan the transponder with the update option activated. Quote
dmcq Posted August 9, 2008 Author Posted August 9, 2008 Lars I did a complete rescan, re-imported the ITV.ini file and all seemed well, the channel played, recorded and played back fine. Thank you very much indeed. However although the recorded file will play back in both DVBViewer and PowerDVD 8 Ultra, it shows the same problem in both as follows. If the recording is started from the beginning and left to play it is fine all the way through, but if you fast forward or back then play it there is severe blockiness. Resetting the file to the beginning again and then immediately fast forwarding then playing it, is normally ok. ITV HD is the only material that shows this problem, BBCHD is always perfect. Could this be a problem with the way the file is recorded? Once again many thanks for your commitment. Regards Don Quote
Griga Posted August 9, 2008 Posted August 9, 2008 Could this be a problem with the way the file is recorded? Rather a problem with the H.264 decoder having difficulties to get "in sync" with the stream. Quote
dmcq Posted August 9, 2008 Author Posted August 9, 2008 Given the decoder is ok with everything else, do you think that the stream is non standard? Quote
Griga Posted August 9, 2008 Posted August 9, 2008 H.264 as a standard is very complex, and encoders / decoders / other involved components may have differing opinions about implementation details. You may want to use the H264ParamReader (-> members area -> tools) for comparing the H.264 headers. Quote
twol Posted July 26, 2009 Posted July 26, 2009 OK - have just installed DVBViewer Pro and although most things seem to go OK, I still cannot set up to view ITVHD. I can get audio but NO Video - have tried all the usual tricks a la sat receiver tricks and cannot get it to work. What parameters are people with a working ITV HD using? Appreciate help. Regards Quote
uglyned Posted July 26, 2009 Posted July 26, 2009 Try downloading this then importing it using channel editor. Quote
twol Posted July 26, 2009 Posted July 26, 2009 Try downloading this then importing it using channel editor. Have imported and will try when ITV next shows a program Many thanks Quote
uglyned Posted July 26, 2009 Posted July 26, 2009 (edited) It should show you a picture anyway. Black screen, ITV logo and some message about no programme currently being shown. Does BBC HD work OK? EDIT - as a quick fix i added more info to the first post of this topic. Edited November 2, 2009 by uglyned Quote
