Update EPG data in EPG Menu Screen
DannyHo
Since i was found that the EPG data usually is not updated, even i have change the TimeZone to GTM +8. Now i need to manual delete the epg.dat from configuration folder and restart program to make it update.
If possible, please add a "Update EPG" button on EPG Menu Screen. So that the user can update the EPG data without restart program. I think this function will be very useful for most people.
A user from Hong Kong.
Thanks.
Thanks.
I have sayed this thing too... Many times... And also saving recording list as soon as possible because if program crashes then every record setup are missing what are not saved...
- Tare69
