Using DVBViewer Pro 3.9.4 with the remote control of a SkyStar 2pCI
marvil69
I know this may be a bit offtopic, but I'm having problems using the remote control, can't find or don't work some basic functions lie 'esc'. Is there a way to define which button makes what? Can't get rid of the keyboard..
Thanks in advance
Go to Options- Input and you have to learn keys. This way you will be able to map remote keys to DVBV.
Thank you! I was lost and didn't expect it to be that easy
Welcome. Good to know that you got it working.
