Work like nebula digiTV software
Eyerex
Hello all i just wondered is it possible to make DVBViewer work like nebula's digiTV software where when you start pc it starts up ready to use ( hibernates in taskbar )also if you click shutdown it hibernates ready to work which is like Disable AV on minimize on DVB but works from the shutdown which keeps the minimizes to just minimize
Sorry if thats as clear as mud but if you have used digiTV software you will understand :blush:
For Start up use a shortcut in the autrun folder. Add in the shortcut some parameter ...\DVBViewer.exe -c -x16382.
The same shortcut can be used to bring DVBViewer back in this mode (it is allthough possible to integrate such a command in the OSD Menu or put it on a key).
If you like to build a shortcut to bring the DVBViewer back and starts TV the paramert are ...\DVBViewer.exe -x16397 -x63.
well if you like this software so much, stick with it. No use for all others making the viewer a clone of it.
Thanks for your help Tjod
