How to display the fancy Menus?
blackosx
Yesterday, I bought DVBViewer Pro and I have to say it's great. It gives me fantastic picture quality through my satellite dish, BBC HD looks amazing and in digital audio too.
I have seen screenshots with menus on the left side of the screen like the Xbox... How do I get this up? I can't find any reference to activating it anywhere.
Embarrasingly
Nick
Better first stick to the default skin. When you got used to the workings of it you can become a little more daring and try other OSD-Skins :D
Hi Tjod
Thank you. I will give it a go.
Thanks for the quick reply.
Nick
And thanks too Lars..
I shall have a play and as you say, get used to it first.
Thanks
Hi, not sure if this is correct but try changing the skin. On the default skin you get top down menus on others the menus are different.
What DVB-s2 are you using?
Frank
